cant Able to change secure print deletion time
  • gksapple
    • Apr 2014
    • 116
    [Misc] cant Able to change secure print deletion time
    Hi
    want change to change the job storage time to the maximum of 3days in secure print ,
    logged in as administrator but the option is grayed out .
    setting & Reg - fuction - print - job storage time (grayed out )
    please hava look on the attachement
    thanks
  • giogi
    Engineer senior
    • Jan 2016
    • 181
    Re: cant Able to change secure print deletion time
    Lev 2 COPIER>OPTION>DSPLY-SW>UI-PRINT>set 1
    OFF/ON device
    Enter the user mode and change the wished time interval
    Function setting>Printer>Printer settings>Settings>
    Lev 2 COPIER>OPTION>DSPLY-SW>UI-PRINT>set 0
    OFF/ON device
    easy
    "Knowledge is a source, but unfortunately ignorance is a sea."
    • nicknt82
      • Nov 2011
      • 155
      Originally posted by gksapple
      Hi
      thanks
      You must log in with Administrator account , if not, some items will gray out can't be changed
