SATA FLASH PCB _imageRUNNER ADVANCE 8105 / 8095 / 8085 / 6075 / 6065 / 6055
  • teckat
    • 16083
    [Error Code] SATA FLASH PCB _imageRUNNER ADVANCE 8105 / 8095 / 8085 / 6075 / 6065 / 6055
    Is it possible to move the SATA FLASH PCB from one machine to another machine?
    No. Never move the SATA-FLASH PCB from one machine to another.
    The Flash Board is a component that is matched to the machine it comes with and can not be moved to another machine.
    CAUTION:
    The second-hand FLASH PCB cannot be used in another machine. If the FLASH PCB is moved to another machine an E748-9xxx will be displayed.
    By installing the FLASH PCB into another machine and turning on the power, the machine specific information will be written in the PCB automatically.
    ADVANCE 6275 / 6265 / 6255
    Sata Flash PCB. The part number for the Sata Flash is FM4-2488-010.
    The following photo shows the location of the Flash Board on Main Controller PCB 1.
    Left Main 1 > lower right side bottom edge of pcb.
