to maintenance, i clean the fuser unit. when finish and turn on the machine, it did not working and error 105 flash. I checked the jacks again and did not find anythink.
Whether the code is correctly named? The error code looks as: Е0...ХХХ-YYYY. Name precisely, pls, ХХХ-YYYY, as code Е105 is not defined. However, in any case it is useful disconnect and then connect the connector of the video PCB, disconnect and then connect the DC controller PCB.
Good luck
Hardworking people are not present. Simply many it is boring to idle.
