Footer on every print and copy on IRadvance c 355i
  • fchu5959
    Field Engineer
    • Jun 2010
    • 100
    I would appreciate if someone could tell me how to hide the footer that is printed on every print and copy.(see attached file).
    This footer shows Date and Time,user name,ip address and serial number of the mfp.
    Thanks in advance.Footer.pdfFooter.pdf
  • teckat
    • 16083
    Re: Footer on every print and copy on IRadvance c 355i
    Thanks in advance.[ATTACH]46425[/ATTACH][ATTACH]46425[/ATTACH]
    Changing/Canceling the Header/Footer Settings
    • fchu5959
      Field Engineer
      • Jun 2010
      • 100
      Thanks for your response Teckat.Your link forward me to the ir desktop which the customer is not using.Also the footer is printed even when you make copies.
      • giogi
        Engineer senior
        • Jan 2016
        • 181
        this is a function enabled in user modes.
        enter as administrator
        Function Settings > Common > Print Settings > Forced Print Recognition Information
        "Knowledge is a source, but unfortunately ignorance is a sea."
        • fchu5959
          Field Engineer
          • Jun 2010
          • 100
          Hi giogi,
          Thanks a lot for your help.You make my day.
          happy wk end and take care.
