Canin IR 1025 IF
  • jper34
    • Sep 2011
    • 225
    Canin IR 1025 IF
    Hi Folks,
    anyone have issues with the document feeder on this copier?
    I replaced pick-up,and feed roller & sep.pad.
    almost seems like the top door pulls out of it's holes, quite easily...any tech pubs, regarding this issue, I could try to replace the top cover, but thought I'd check with you guys, and fixes or finds. What I did see, it would read a jam, after the sheet came out of the feeder..any help, suggestions, greatly appreciated !
    Thanks,
    Jaime P.
  • Brian8506
    • 1664
    Re: Canin IR 1025 IF
    I have had problems with a sensor flag falling out of its cradle inside that cover.
    • jper34
      • Sep 2011
      • 225
      I thought of that, too..do you remember what you did, that actuall fixed it..?
      or replace the whole top cover?
      • Brian8506
        • 1664
        I just reseated the flag. If the cover is popping out of its holder you may have a crack in the mounting post. I have had those break
        • jper34
          • Sep 2011
          • 225
          Thanks Brian,
          that sensor arm was just hanging, I was lost, as the 1st. visit, I ran a good pages thru doc. feeder. I did repair the post that holds the arm in place
          Thanks !
