IR 6570 RDF misfeeds
  • bizhub1
    • Sep 2008
    • 230
    I am having intermittent misfeeds on the rdf with a jam code of 0001, I have replaced the feed mag clutch but still having problems. Any help would be apprectiated.
  • chrisb19036
    • Jul 2008
    • 16
    hey bizhub, I'm assuming that the rollers are new or fairly new, I have in the past had to replace the entire link assy connected to the mag clutch in order to rectify interrmittent jamming in the adf. did you try the adf adjustments as well. also did you check the position of the pressure spring on the seperation pad? just a thought hope this helps.
    • bizhub1
      • Sep 2008
      • 230
      Yes I have replaced the rollers and pad, I checked the spring but I have not did the adjustments, I will give that a go today. Thanks for the info.
