Canon IR 5570 Lead Edge fade
  • StephenB
    • Aug 2015
    • 244
    I'm more a Ricoh tech, but have worked a fair amount on these Canon IR's.
    Have an IR 5570 started out where it would very intermittently not transfer the image, on the lead edge ( see sample )
    Now 2 of 5 pages come out with the lead edge poorly transferred / faded.
    This unit has over 2 million pages, I believe it's the original drum. Otherwise copies are excellent.
    I have a working 5070, tried changing the transfer corona assembly, the end block where the assembly inserts,the development unit. Tried adjusting voltages in adjustments screen. Same problem
  • Brian8506
    • 1665
    • StephenB
      • Aug 2015
      • 244
      Re: Canon IR 5570 Lead Edge fade
      Thanks Brian, but I am using quality paper, and I have 2 units in the same room using the same paper. I believe this is some kind of separation or transfer issue. Or High voltage short / leak
      • Brian8506
        • 1665
        There is a cable from back of T/S unit to the HVT. How about legal or ltrr?
        • StephenB
          • Aug 2015
          • 244
          I have checked that cable, Looks normal, and I re-seated. still faded
          Regarding the "block" on the rear frame ( Machine) that the T/S unit drawer inserts into - is it known to fail and short ? Or the HV board ?
          Thanks again for any assistance
