Image prograf W6200
  • dpepin
    • Dec 2007
    • 51
    Image prograf W6200
    Hi to you all dear techs!
    i'm searching for a service manual for the Imageprograf
    W6200, i have a problem with the yellow indication not
    enough ink. i Replaced the toner yellow toner tank but
    it seems that the printer don't reset the bar toner level.
    i don't know what's wrong with that printer, and the best of all is that i'm not trained on that machine. so if someone could help me i would appreciate.
    thanks
    Denis
  • SCREWTAPE
    • Jul 2025
    To reset the maintenance cartridge counter in Service Mode go to Counter- Clear-CLR-MTC Exc. (clear maintenance cartridge executable).
    To access SVC-MODE
    1. Turn off the printer
    2. Turn on the printer while holding down the Paper Source button and online button.
    3. Check that "Canon W6200PG" is shown on the display, and then release the buttons.
    4. Next, "SERVICE MODE" is shown on the display. (If sheets are inserted, this will be displayed after the sheets are loaded.)
    5. Use the [v] button to make a selection.
    To exit the service mode, turn off the printer.
    In the service mode> Display> Print INF > select Yes , that will give you a complete print out of the information that you need.
    Hope this helps.
    ScrewTape.
    • dpepin
      • Dec 2007
      • 51
      reply from denis
      as stated there's no problem with the maintenance cartridge but the yellow tank is in trouble.
      but if you know how to initialize the toner level just let me know.
      thanks screwtape
      Denis
