Canon Image Runner 4245 Jamming
  • lbotto
    • Sep 2020
    • 3
    [Jamming] Canon Image Runner 4245 Jamming
    I have a customer with a canon ir4245 that is jamming when duplexing. Single sided prints are fine. After the jam there is always paper sitting mostly in the No 2 delivery assembly and just a bit would have been in the duplexing guide assembly. The jam code is: 00 010D DELAY S7 Duplex feed sensor
    Any thoughts on why and how to fix?
  • Brian8506
    • 1664
    Re: Canon Image Runner 4245 Jamming
    There is a belt in the 3 way unit that may have popped off. If you pull the unit it should be easy to see.
    • lbotto
      • Sep 2020
      • 3
      I forgot to add a lot of times a piece of paper will be sitting in between the adf assembly and the output bin. Not sure how it gets there. Is the 3 way unit the internal finisher??
      • Brian8506
        • 1664
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Look in the area could be dirty sensor
          Regards Mark
          • lbotto
            • Sep 2020
            • 3
            So I replaced the entire right door and still jamming when duplexing. Any other thoughts??
            • kstan268
              • Apr 2012
              • 85
              i also faced the same problem recently..Do you had already solve the problem? pls help !!!
              • THUK
                • Jul 2008
                • 195
                Does it jam if you run A4R
                • kstan268
                  • Apr 2012
                  • 85
                  problem solve by replace inner two tray (belt came out only)but problem solve with helping from many fren Thank's guy
