Detach finisher unit from IRC3580I
  • rzepa
    • Sep 2020
    • 1
    [Misc] Detach finisher unit from IRC3580I
    Hi all,
    I have removed the buffer path unit and the finisher with the puncher unit from IRC3580I, because i dont need them and and they cause paper jams in this unit.
    However after simply detaching the connection cable from the finisher to the main unit there is the well know error message E000732-001.
    Although I have the complete service manual I did not find a possibility to tell the system that there is no finisher anymore.
    Because I need the printer very urgent I would be very thankful for any help!
    Re: Detach finisher unit from IRC3580I
    732 is a reader connection error check the reader cable at the left-hand side and rear of the machine.
    As you removed the buffer unit you will need the delivery sensor flag FC5 0799
