What have you done? Retire Coronas. Transfer belt? Clean out laser?
Replaced the Primary Corona Assembly, belt, drum blade, I noticed that when I lift the corona wires the printout is clean but only 20 pages, after that the lines come back again.
Another thought. On top of the dv unit are 2 brass contacts. Bend them up a little to make better contact inside the copier. I've solved a few odd cq issues with that.
