ir 7095 power on machine keep on jamming at the fuser roller.
  • lalynbb
    • Sep 2020
    • 12
    [Jamming] ir 7095 power on machine keep on jamming at the fuser roller.
    I have changed the sensor PS10, PS9, PS6 and clutch and gear below the fuser unit.
    but still the same problem, Thanks for help.
    Jam code : 0A1A
  • tsbservice
    Field tech
    • 8020
    Re: ir 7095 power on machine keep on jamming at the fuser roller.
    If it jam constantly at fuser roller then check fuser rollers drive. Usually drive gear boss is broken or gear itself. Speaking of other brands(non Canon) I normally work on.
    • mc007
      reliable tech
      • Jan 2019
      • 28
      Jam code : 0A1A
      check fuser upper roller and drive gears , part no: FS7-0007-000,FS7-0006-000
      • lalynbb
        • Sep 2020
        • 12
        Thank you. I will try it
        • lalynbb
          • Sep 2020
          • 12
          thanks I will try this out.
          • lalynbb
            • Sep 2020
            • 12
            all the gear at fuser or upper roller is ok. but the problem still the same,any suggestion?
            • mc007
              reliable tech
              • Jan 2019
              • 28
              jam code ?
                • 16416
                Do you know for sure that the fuser is turning during normal operation? I used to put a mark on the the lower fuser roller with a sharpie to verify it's turning. Also, have you checked all the relevant sensors to make sure they change states from 1 to 0?
                • lalynbb
                  • Sep 2020
                  • 12
                  jam code ?
                  • lalynbb
                    • Sep 2020
                    • 12
                    Noted, great idea! next time i can try to use your skill to make sure it.
                    i changed all sensors around fuser unit. but still the same.
                    After that I changed whole unit from other machine, then it work as well.
                    But now another problem come, upper fuser roller unit is too hot.
                    the machine keep on restart.......
                    do you have any idea for me?
                    Thanks a lot~~~~
