irc 5035 Cassette Heater for host machine don t warm
  • ernesto
    • Oct 2011
    • 430
    HI
    I have a irc 5035 Cassette Heater for host machine don t warm, the same Cassette Heater for host machine in other machine irc 5035 works
    does any one what board run the cassette heater for host machine and the pin conection?
    All the best
    Re: irc 5035 Cassette Heater for host machine don t warm
    Originally posted by ernesto
    HI
    All the best
    isnt there a software sw you have to turn on?
    • ernesto
      • Oct 2011
      • 430
      I think you only have to turn on a mecanical switch above the plug (in other machine irc 5035 I did that and it worked)
        ok then print out the settings from the working machine and compare to non working unit
        • a9651
          • Sep 2020
          • 2
          1,检查主机电源上方的开关是否打开,如果没有打开请打开。
          2,关闭mfp主电源(显示屏右下方)
          3,等待15-30分钟,加热器表面应该有升温。
          4,如果有升温,说明是mfp控制的。
          5,如果没有升温,可能加热器或者加热器控制pcb有故障
          供您参考,祝早日解决问题
            2,关闭mfp主电源(显示屏右下方)
            4,如果有升温,说明是mfp控制的。
            供您参考,祝早日解决问题
            in english?
            • tsbservice
              Field tech
              • 8006
              2,关闭mfp主电源(显示屏右下方)
              4,如果有升温,说明是mfp控制的。
              供您参考,祝早日解决问题
              Please try to use Google translate.
              OP this heater plugs in some board, right?
                • 16374
                2,关闭mfp主电源(显示屏右下方)
                4,如果有升温,说明是mfp控制的。
                供您参考,祝早日解决问题
                Here's what he said in English:
                1. Check whether the switch above the power supply of the host is turned on, if not, turn it on.
                2.Turn off the mfp main power (bottom right of the display)
                3. Wait for 15-30 minutes, the heater surface should heat up.
                4. If the temperature rises, it is controlled by mfp.
                5. If there is no heating, the heater or heater control PCB may be faulty
                For your reference, I wish an early solution to the problem
                • tsbservice
                  Field tech
                  • 8006
                  Thanks Billy I always do my homework but other readers aren't obliged.
                  Atm I'm thinking right next to what Phil did always when someone especially new users post in whatever language they speak.
                    exactly... how many can read/understand what was written WITHOUT translating it?
                    with the majority of people here that type in english EVEN if it isn't their primary language, why the hell should we have to use a translator?
                    he could type in his profile information in english:
                    Date of Birth July 28 About a9651
                    Country:JapanWhere are you from (City, State):tokyoTechnician Status:Technician (2-10 Yrs)
                    he isn't even in the newbie check-in forum.
                    he has made 2 posts today both in his native tongue.
                    Bet he hasn't even read the forum rules nor the FAQ pages (lots of info there)
                    Yes we here at CTN are an international site but VERY few people are rude enough to post in an uncommon language.
                    I would much rather read a fix/suggestion in broken english than have to copy n paste into some damn translator.
                    Do you go to an all spanish speaking house and speak english?
                    I have MANY MANY hispanic friends that normally speak in their native, but when I come in they speak in english/simple spanish that I can understand. But many label the hispanics as rude, I don't see it.
                      • 16374
                      I appreciate that you keep things in order on this site. It's not always popular but it is necessary.
                      • tsbservice
                        Field tech
                        • 8006
                        I used to be more mild on that type of posts but I was wrong. Few or nobody of them became more of one or two time poster. Not to mention that Google translate discover these hieroglyphs as Chinese but poster is in Tokyo Japan. Perplexing.
