Canon iPF755 Error - 2F3A
  • MadCityCopy
    ieeeee
    • Oct 2010
    • 58
    [Error Code] Canon iPF755 Error - 2F3A
    Happy Sunday,
    I wanted to get some techs opinion on where to go with this repair. Plotter just started throwing this code. I am not able to get into normal service mode, the small "S" pops up when I hold the buttons but it just never kicks in. Just goes into the error state. I have removed the covers and the ink supply units on both sides. With my hand, I manually rotated the gears and saw the cycle complete as far as I can tell.
    Started searching around and seen here that it may also be the Purge Unit. Or worst case Main PCB. Should I look at getting a new purge unit? I reseated the inks as well as the print head with no change. I have not attempted Firmware yet as it doesn't seem to get into that state to preform.
    Any assistance would be greatly appreciated.
    Re: Canon iPF755 Error - 2F3A
    Originally posted by MadCityCopy
    Happy Sunday,
    Started searching around and seen here that it may also be the Purge Unit. Or worst case Main PCB. Should I look at getting a new purge unit? I reseated the inks as well as the print head with no change. I have not attempted Firmware yet as it doesn't seem to get into that state to preform. Any assistance would be greatly appreciated.
    well a purge unit will be cheaper than main PCB... that being said.. FIRMWARE.. purge.. main bd
    • MadCityCopy
      ieeeee
      • Oct 2010
      • 58
      Any idea about the not being able to get into service mode?
      Learning now about the Download Mode. I assume I should look at entering that mode and loading the firmware. I am using my MAC. I found an update tool so I feel I should be able to complete this. Or am I going to need to load firmware a different way?
        sorry no comprende MAC
        • MadCityCopy
          ieeeee
          • Oct 2010
          • 58
          Download mode is what I should use for firmware when the machine wont fully boot?
            first verify the HDD is mounted and good
