Canon IR-6055 E-0060 Code?
  • NSCT
    • Feb 2010
    • 50
    Have a 6055 with A E-0060 Code which shows as Primary corona issue. Tried resetting in service mode but just comes back. Primary unit looks okay. Any ideas before I order a new corona unit? Thanks for any and all help!
  • Brian8506
    • 1664
    Re: Canon IR-6055 E-0060 Code?
    It may be a problem with the shutter on the primary. I had that and had to replace the little brass piece that rides in the worm gear
    • Brian8506
      • 1664
      Replacing the primary should fix it
      • oombees
        • Apr 2016
        • 27
        Replace the primary home position sensor. I have had a few that failed
        Sent from my MAR-LX1M using Tapatalk
        • NSCT
          • Feb 2010
          • 50
          Thanks for the info. I have a new primary assembly coming. Would you by chance have the part # for the sensor? I do not have a parts manual for the 6055. Thanks again for your help.
          • oombees
            • Apr 2016
            • 27
            See Attached
            • NSCT
              • Feb 2010
              • 50
              See Attached
              Thanks much for the help. I will get the sensor ordered.
              • NSCT
                • Feb 2010
                • 50
                I ordered a new sensor. I opened the fan door for access and only see one sensor that is located on the bottom right side of the door. It does not look like it has to do with the primary corona. I went ahead and replaced this senor but still have the E-060 code. Any other suggestions? I also have a new primary corona coming. Thanks again for the help.
                • Brian8506
                  • 1664
                  I've never replaced it but if it's a wire cleaner home position sensor it would be above the charge corona.
                  • NSCT
                    • Feb 2010
                    • 50
                    Nothing above or around the upper primary corona. The lower pre cond corona has a sensor which is the one i replaced.
                    • Brian8506
                      • 1664
                      • NSCT
                        • Feb 2010
                        • 50
                        Replacing the primary unit took care of the problem. No primary position sensor on the 6055. Thanks!
