Touch Screen issues with IR4525iii
  • Copybox
    • Sep 2020
    • 59
    [Misc] Touch Screen issues with IR4525iii
    Canon touch pad on this jumps to the next selection when you select choice, for example when you press home key, personal settings highlights. Can this be fixed in service mode ? If so where, as this may be a calibration bug
    Thanks J
  • 20 year tech
    • May 2014
    • 577
    Re: Touch Screen issues with IR4525iii
    You can try to calibrate the touchscreen in service mode Copier>Function>Panel>Touchchk a series of * marks appear on the screen touch them with a stylus to calibrate.
    • Copybox
      • Sep 2020
      • 59
      Thanks for your help will give it a try tmw!
      • giogi
        Engineer senior
        • Jan 2016
        • 182
        if you can't because the touch is too out of adjustment try this:
        enter service mode and press button 5 3 times.
        Then press the crosses on the display and make calibration
        "Knowledge is a source, but unfortunately ignorance is a sea."
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          clean dirt out from around the edges of the touch panel first
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • Copybox
            • Sep 2020
            • 59
            Thanks for all your help guys the press 5 x 3 times worked and re-calib all done machine is working customer is happy
