Canon iR 3225 freezes/hangs
  • chetanchopra25
    • Feb 2013
    • 25
    I am maintaining a Canon iR 3225. The copier hangs couple of times every day. The screen does not accept any command, the panel does not accept any command, no print out comes out, even the RUI does not come up. But the PING command works. After rebooting, it works fine for sometime and then again the same problem starts.
    I have changed the IP board, hard disk, counter and RAM but to no avail.
    Any help would be appreciated.
  • Brian8506
    • 1665
    Re: Canon iR 3225 freezes/hangs
    Firmware update
    • Kkh
      • Jul 2020
      • 7
      do numeric keypad work?
      • chetanchopra25
        • Feb 2013
        • 25
        No, the numeric keypad also does not work. After reboot, eveything works for few hours before the same problem starts again.
        • Brian8506
          • 1665
          You need to update the firmware
          • chetanchopra25
            • Feb 2013
            • 25
            Originally posted by Brian8506
            Firmware update
            That's why I changed the hard disk also. But no effect.
            • Brian8506
              • 1665
              • Kkh
                • Jul 2020
                • 7
                If the door opens to the right, what does the sensor on the screen detect? if you detect the possibility that your panel is a problem. try changing the pcb on the panel.
                • techandtrader
                  • Jun 2016
                  • 335
                  Known problem Must update with USB or SST
                  I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
                  • Brian8506
                    • 1665
                    I think you can only update with SST
