Canon offline
  • Valintine
    • Jan 2012
    • 147
    Canon offline
    Hello
    I have a Canon ir 8285. It is on my network, I can ping it and get to the web interface but when I install the print driver it says it is offline. I did check in the service mode it the interface is set to 0. I work mainly on Toshibas but we brought in this special order. Any suggestions would be greatly appreciated.
    Re: Canon offline
    Originally posted by Valintine
    Hello
    sounds like it's a WSD port it's on.
    don't use WSD
    • kuby
      • Oct 2007
      • 1409
      Re: Canon offline
      I would agree with Phil. Take it off WSD and install it with a IP address. Had a lot of trouble with WSD drivers.
        Re: Canon offline
        another thing.. if it's on a win10 system.. install PCL6 driver.. no universal driver machine specific
        win 10 has a problem printing with a PCL5 driver.
        • Valintine
          • Jan 2012
          • 147
          Re: Canon offline
          Thankyou for the replies. I am using an ip port. I have not had much luck with the wsd ports. At first I was using the ufr generic driver but now I am using the pcl6. One strange thing I am having happen sometimes when I restart my computer a test page or two prints out. This one is getting me. I will keep trying your suggestions.
            Re: Canon offline
            don't know where but the startup page should be in the driver setup
              • 30293
              Re: Canon offline
              Uncheck SNMP under ports tab
              If you still have a issue assign it a difference ipadress and start over
              • Valintine
                • Jan 2012
                • 147
                Re: Canon offline
                Hello
                With your suggestions I have been able to have the driver see the 8285 online. When I click print the data light lights up for a second but the machine does not print. When I look at the print out of the log it say NG #860. I tried finding it and if I am reading the info correctly the print job is trying to use a function that the machine does not have. I checked the settings and it looks like I have it set correctly. Any more thoughts? Again thank you all.
                  • 30293
                  Re: Canon offline
                  Hello
                  Used the canon driverURF II or pcl driver
                  Postscript is an option not installed.
                  • Valintine
                    • Jan 2012
                    • 147
                    Re: Canon offline
                    And that did it!! Thank you everyone for your help. I had started with the ufr driver and then changed to the pcl6. After I tried the suggestions I switched back to the ufr driver and it started printing out the test sheets that were held up. I can not say exactly which change or combination of changes did it but thank you again.
                    • Venom
                      Technical/IT Support
                      • Nov 2009
                      • 765
                      Re: Canon offline
                      If it gives trouble again, try changing IP address of device. Out of DHCP range preferably.
                      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
