c2230/c5250 Chromebook printing
  • ReproKev
    • 273
    I'm thinking of placing an older Canon c2230 or c5250 (possibly a newer model if necessary) in a very small school. They want the kids to be able to print to it from their Chromebooks. I can set up Mac's and PC's with no problem, but I've never worked with Chromebooks.
    Is it possible to print from a Chromebook?
    Do I use the Linux driver?
    Any special settings I need to be aware of?
    • 30293
    Re: c2230/c5250 Chromebook printing
    Yes you can print
    Some printers have build in cloud support
    Check for PPD driver
    check out youtube video's on setups or contact tech support for the brand you wish to connect
    good luck
    • Lewis-H
      • Oct 2020
      • 15
      In the search box, you should type 'print'. Select the 'Printers' option in the next window. Select the 'Add Printer' option and a list of the available printers appears. Select your printer and follow the on-screen instructions to connect your Chromebook to the Canon printer.
