Canon IR adv C5045i Problem with black bar is shorter than the other.
  • NC Print
    • Mar 2019
    • 1
    [Misc] Canon IR adv C5045i Problem with black bar is shorter than the other.
    I have problem when I do test 10 that black bar is shorter than the others.
    How to solve it. Thanks to every reply.
  • 20 year tech
    • May 2014
    • 577
    Re: Canon IR adv C5045i Problem with black bar is shorter than the other.
    [ATTACH=CONFIG]46999[/ATTACH]
    What have you tried so far ? I see a bigger issue with your yellow than the black.
    • MunsterTech
      • Sep 2014
      • 381
      Your registration is way off, check the operation of your patch sensor shutter / patch sensor. the shutter has a little nipple that can break off so when the solenoid gets activated the shutter doesnt move or moves partially.
      • giogi
        Engineer senior
        • Jan 2016
        • 181
        I have solved it by cutting the clamps that hold the signal cables to the laser driver.
        cut all the clamps under the drum/developer, around laser connector (side operator).
        "Knowledge is a source, but unfortunately ignorance is a sea."
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          Black drum may not be sitting properly. Take apart the laser units and clean mirrors and lens, reassemble, clean patch sensors and run color mismatch. Then do auto grad and see if aligned. Can be adjusted in service mode if still misaligned.
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Easy most common problems dirty id patch sensor clean then do colour mismatch adjustment. But could be caused by over life parts as well check pm lifes
            Regards Mark
