Canon IR Advance C5535 Paper Trays Not Being Pulled in Or Lock In Place
  • tecchie
    • 120
  • tsbservice
    Field tech
    • 8019
    Re: Canon IR Advance C5535 Paper Trays Not Being Pulled in Or Lock In Place
    Looks you're right, some Konicas will do the same and you need to perform trouble reset after cleaning jammed paper to clear the code.
    Just wait for Canon guys help here.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      During transport, metal plate deforms inside the machine.
      Remove all paper cassettes out and you'll see.Remove and fix the plate.
      Gene III has this modified.
      • tecchie
        • 120
        This was resolved. Both paper trays were not drawing in and locking. What i found was that both cassette auto close assemblies spring units inside completely reversed to the forward position. Once i took them out of the paper tray unit and reversed them back it now works fine. Not sure how they got that way. This all started with a paper jam behind trays.
