Ir avd 8285 print and fotocopy quality problems.
  • ktleoh80
    • Mar 2011
    • 21
    Hi everyone, I facing a printing and photostat quality problem. Primary charging already change the corona Wire, and sub charging also. But still poor quality. Anyone can advise and suggest t what should I do. Thank you very many. I also attach the problem copy. wx_camera_1604129949543.jpg
    Re: Ir avd 8285 print and fotocopy quality problems.
    In service mode level 1 changed COPIER>ADJUST>HV-PRI>PRI-GRID to 0. Next in service mode level 1 changed COPIER>FUNCTION>DPC>DPC to 1. Then turned the main power OFF and ON (potential control is executed at startup). All copy quality was good after the power cycle.
    • Gab
      • Aug 2015
      • 670
      have you cleaned corona grid?
      HAve you cleaned optics?
      • ktleoh80
        • Mar 2011
        • 21
        Thank you for u reply. I did all the setting but still the same. I mention that when I set to 'text'. The output quality is OK normal. I can't ever use the'text photo' or 'photo' setting. Result will get poor quality print out. Have any idea?
        • ktleoh80
          • Mar 2011
          • 21
          I already change the corona Wire. Still same poor result.
          May I know where is the optics located?
          Thank you.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5007
            Inspect values from the door with values in service mode.Toner is OEM?
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Originally posted by ktleoh80
              Hi everyone, I facing a printing and photostat quality problem. Primary charging already change the corona Wire, and sub charging also. But still poor quality. Anyone can advise and suggest t what should I do. Thank you very many. I also attach the problem copy. [ATTACH=CONFIG]47163[/ATTACH]
              What's the pm part list are you using oem toner
              Regards Mark
              • ktleoh80
                • Mar 2011
                • 21
                I am using third party toner. I got 2 machine using the same toner. 8295 no have any problem but 8285 got this kind of problem. May be some setting or hardware problem? Somebody can help? Thank you.
                  sounds like a toner issue to me.
                  • ernesto2019
                    • Jul 2019
                    • 14
                    It worked for me:
                    1. service mode aditional fuction *28/ copier / options / fnc-sw / po-cnt / valor 0
                    2. Level 2
                    copier / options / fnc-sw / po-cnt / valor 2
                    3. then we go back to level 1
                    copier / adjust / develop / bias / valor 200
                    • nicknt82
                      • Nov 2011
                      • 155
                      How about print from computer, if it's OK. You can change scanner density on user mode
                      Top > Maintenance > Adjusting Print and Finish Quality > Adjusting Density
                      • tinnyjay
                        • Oct 2009
                        • 663
                        Clean the laser.
                        "Who loves the roses,must also bear thumbs"
