Ir adv 8105 two sided paper jam only for A4 size paper
  • Mahaveer.Tambe
    • Jun 2019
    • 2
    Canon ir adv 8105 two side jam
    Hi
    Canon IR Adv 8105 jams when i print / copy two side only on A4 paper there jis jam in duplex assembly. It works on A4-R no paper jams in single / two sided print / copy. Paper leave fuser unit and go down to change side, but stops there and sometimes is curled. Jam code is PS65, When i print in single on A4 there is jam and everything its ok.
    There is a selenoid S5 (REVERSE SOLENOID ASS'Y) and i changed it thinking its faulty. I have opened and checked for any prob, but found nothing.
    Re: Ir adv 8105 twi sided paper jam only for A4 size paper
    Hi
    Canon IR Adv 8105 jams when i print / copy two side only on A4 paper there is jam in duplex assembly. It works on A4-R no paper jams in single / two sided print / copy. Paper leave fuser unit and go down to change side, but stops there and sometimes is curled. Jam code is PS65, When i print in single on A4 there is jam and everything its ok.
    run motor sensor tests.
    • tinnyjay
      • Oct 2009
      • 663
      Re: Ir adv 8105 two sided paper jam only for A4 size paper
      Hi
      Clean/change duplex registration sensor and motor in the duplex.
      Its a delay to PS65.
      If had to be reverse roller on the entrance of duplex, the jam code would be PS66 (delay).
      "Who loves the roses,must also bear thumbs"
