irc 355 itb assembly inundated with waste toner
  • ernesto
    • Oct 2011
    • 428
    HI
    I found a irc 355 with itb asembly inundated with waste toner
    it seems every thing is ok, the waste toner motor turning around and the hole betwen itb and waste toner is empity
    Does anyone knows the problem?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4955
    Re: irc 355 itb assembly inundated with waste toner
    Nothing smart.
    ITB is not super quality in this model.
    1) Replace the ITB unit and registration drive assy FM1-A225-010
    2) Execute counter clear in the Service Mode-COPIER > COUNTER > DRBL-1 > TR-BLT > "OK"
    3) Change the Service Mode Values.
    < Increase the width of the band>-SERVICE MODE > LEVEL2 > COPIER > OPTION >CLEANING > DR-CL-L >change to “40”.-SERVICE MODE > LEVEL2 > COPIER > OPTION >CLEANING > DR-CL-T > Change “-3”.
    Practice makes perfect
    If you want something done right, you have to do it yourself
    • ernesto
      • Oct 2011
      • 428
      I replaced itb unit and registration drive assy fm1-A225-010 4 month ago and Thats solved the problem
      thanks a lot ;-)
      • zoraldinho
        • Mar 2008
        • 4955
        thanks a lot ;-)
        Thank you Ernesto
