Code e000002-0010 for canon 5570
  • jprecht
    • Dec 2008
    • 104
    Can someone please tell me what the code is for a canon 5570 code is: E000002-0010 thanks
    IT IS BETTER TO REMAIN QUIET AND BE THOUGHT A FOOL
    THAN TO SPEAK AND REMOVE ALL DOUBT
  • RSCA
    • Jul 2008
    • 112
    My 4570 manual tells me this is a low fuser temp code. Fuser codes need to be reset in the service mode. Power cycle will not do it.
    • victor_v
      • 71
      E002-0010
      Hi jprecht.
      E002 There is an abnormal rise in temperature.
      -0010 The power has been turned off and then back on without resetting the error.
      - Reset the error: COPIER>FUNCTION>CLEAR>ERR
      Hardworking people are not present. Simply many it is boring to idle.
      • jprecht
        • Dec 2008
        • 104
        Hey thank you for your response. somehow my thread got mixed up with someone elses. e002 is pretty common for most canons. do have a ??? for ya on c 5570 after boot up only mailbox appears on header how do you reset to use as a copier have no books not even intravia on this one. box is set up as a printer only. thanx jp
        • Ikon Princess
          • 126
          enter service mode *28*>copier>option>body>w/scanner>set to 1>ok then reboot copier. This worked for me.
          • SteveO
            I have had troubles with these pesky error codes even after replacing the fixing assembly. Canon is working on a firmware update for them. the only fixes i know of for this is turning sleep mode off or replacing the surge protector. These machines are very sensitive about voltages.
            • jprecht
              • Dec 2008
              • 104
              c-5570
              thanx all for responses. esp "queen". thankfully box is gone and is someone elses problem. wk for a wholesale outfit see all!!! john
              • mrfixit51
                Lead Service Technician
                • Oct 2008
                • 1975
                E000002-0010
                Hello jprecht,
                If I have done this right, I have attached the printout of the pages in the manual that describe your error. Here goes nothin'
                • Tim C
                  • 167
                  I am getting this Code e000002-0010 on a canon IR5570 only in the morning runs all day fine... Have try many things.. Any body seen this and know the fix?>
