I have a Canon ir8505
  • Arcadian
    • Feb 2010
    • 218
    Turning it on, the power light comes on, then the Energy saver light comes and start pulsating, the copier does it dance, but nothing on the screen.
    unplugged the copier for 5 minutes, same results after turning it on, holding #28 button resulted in nothing, same pulsating energy light, sometime it'll stop maybe flashes 5 or 6 times
    I wonder if anyone seen this happened to a 8505 machine..
    Any suggestions is appreciated .
  • oombees
    • Apr 2016
    • 27
    Re: I have a Canon ir8505
    One of three things you could check.
    1. Main Controller 1 and 2
    2. HDD
    3. Engine Board.
    I had at least one of these three go haywire before.
    Sent from my SM-G985F using Tapatalk
    • Arcadian
      • Feb 2010
      • 218
      2. HDD
      3. Engine Board.
      Thank will look into these.
      I had changed the HDD, possible it failed, did work for a year so maybe it was a bad hdd.
      thanks ill remove to see if it boots up at least that should tell me for sure.
