Drum counter on imagepress c 710
  • fchu5959
    Field Engineer
    • Jun 2010
    • 100
    Hi everybody,
    On an imagepress c710,I am having a hard time resetting the drum counter after having replaced them.According to service manual,this should happen automatically with new drums but this is not the case.
    Has anybody ever encountered this issue? i would greatly appreciate if someone have the solution.
    Take care.
    Re: Drum counter on imagepress c 710
    Originally posted by fchu5959
    Hi everybody,
    Take care.
    genuine OEM drum unit?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
      In service mode go to situation>parts replacement.
      If you follow step-by-step instructions, the drum will reset.
      • fchu5959
        Field Engineer
        • Jun 2010
        • 100
        yes,always use genuine parts.
        • fchu5959
          Field Engineer
          • Jun 2010
          • 100
          I have never gone through "situation" to reset parts counter.
          Anyway,i will give it a try and post back. Thanks Zoraldhino.
          • fchu5959
            Field Engineer
            • Jun 2010
            • 100
            This afternoon,i had the opportunity to replace the magenta drum on this press.I followed Zoraldhino's post and succeded to reset the drum counter.
            So ,thanks again to Zoraldhino for his help.
            Cheers.
