TB articles for a few different colour machines for this particular error code but nothing for the big B/W machines.
It's a fax kit related issue...the articles point to a connection issue.
I reconnected the fax harness at both sides...fax kit AND main controller but the error continued.
I pulled the harness out and snipped the cable ties and tested for continuity and found that two of the wires had been crushed by the cable ties...they didn't read anything on the meter.
I've contacted dealer support to try to find out a part number for the wiring harness and in the meantime pulled the fax kit out so that the customer can continue to print/copy.
I think I'm on the right track but wondered if anyone had struck this code on the Z1 fax kit before?
