IRA C 5540 copy and print rotated 180 degrees
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4999
    Hi,
    The customer called me to have the copies and prints rotated for 180 degrees.There is no problem with printing on or the other side of the paper. When you take the paper out of the tray it is turned upside down. In principle there is nothing wrong but I am interested in what setting they played with.I can delete settings and solve the problem but but I will never know what happened.
    Thanks!
  • giogi
    Engineer senior
    • Jan 2016
    • 182
    Re: IRA C 5540 copy and print rotated 180 degrees
    COPIER>OPTION>USER>PRTDP-SW Set delivery side for 1-page job:2-sided
    "Knowledge is a source, but unfortunately ignorance is a sea."
    • zoraldinho
      • Mar 2008
      • 4999
      Thanks G but im afraid this is for face-up or face-down when printing only 1 page although 2-sided.This one is rotated for 180 deg when printing or copy one sided.
      • Venom
        Technical/IT Support
        • Nov 2009
        • 765
        Maybe try changing orientation of paper in tray just for shits and giggles.
        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
        • zoraldinho
          • Mar 2008
          • 4999
          For example counter print is ok.
          • zoraldinho
            • Mar 2008
            • 4999
            This setting i tested on our machine in service.Off or on.Nothing happens.
            • zoraldinho
              • Mar 2008
              • 4999
              I will export the settings from this device and import it to the device in the field.
              My opinion, only the new system will help.Thanks for the hints guys.
