Canon iRC 3220 C1 network setup
  • moe0303
    • Sep 2025
    Hi, just got one of these in from the wholesaler and I'm trying to configure it to get on my network so I can test it. It has a C1 Fiery on it and I can't figure out where to input the Network settings like IP, subnet mask, and all that stuff.
    I mostly deal with Ricohs, but I have done a few of these Canons but this is the first one with this type of server attached to it. TIA for any help.
  • haydar64
    push printer at screen, and select printer properties, and u must be set up (install) from zero configuration.
    select install network or install sequences, and configure to your network type and IP adresses.
    if this screen is not change in 2-3 minutes, u must power off and re-on your machine and re-enter this menu.
    (sorry for my english)
    • SCREWTAPE
      • Sep 2025
      You must run set up.
      Hit the printer tab on the control panel, if you don't see it hit the arrow to right then proceed to hit printer status>functions>run setup>network setup> and save everything.
      Screwtape
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Your English is better than most native English speakers I've met lately
