Hey,
I have a problem with this IPF605 which I've recently bought. According to the seller the print head was dried, and must be replaced...so it wasn't so expensive.
Anyhow, there were 5 OEM tanks in it, only the blue was missing. Magenta and yellow were running out, so I only had to buy a blue tank to figure out the printer's condition.
I was only able to print in service mode. If service mode wasn't turned on at start, before printing I got an "execute printhead cleaning, if still display same error, replace printhead."
In service mode though I could print some test pages, and realized that every color is perfect, except the blue.
Later on the yellow ran out, so I bought a yellow and a magenta tank as well.
After printing a test page again I see that the blue color got even worse...a lot worse. Before it was maybe in a 50% condition (half of the printed lines were missing), now I only see a few blue lines in the test page.
So I took out the print head, and tried to clean it with a cotton swab dipped in alcohol. The test print is still remained the same.
So here are my questions:
Is it possible that maybe the blue problem isn't print head related? I figured since the blue tank was removed for I don't know how long, maybe it dried in somewhere else and the and the test print was better at first because the ink still came from the printer's system, and now the ink from the new tank can't even reach the print head.
Why is it that I can only print in service mode?
Also after doing a cleaning cycle, the following error message pops up: Hardware error 03800500-2F2F, Turn off printer, wait, then turn on again. Any idea how to solve this one?
I'm guessing the problems are connected, but not sure how to solve it. I will give the print head a proper cleaning later on (if no one gives a better advice
Thanks in advance!
Thanks in advance!
