canon ir c5250
  • onmyski
    • Oct 2012
    • 15
    canon ir c5250
    canon ir c5250 prints solid yellow with the print still visible
    Re: canon ir c5250
    need more info:
    how many pages on drums/developers?
    is the cleaning unit on the belt cleaning?
    any errors recorded?
    genuine oem toners?
    New oem drums?
    copy/print?
    Phil B. ' The Dentist '
    • onmyski
      • Oct 2012
      • 15
      Re: canon ir c5250
      replaced drum and developer, only OEM toner, when it happens it looks like she prnted on yellow paper, 1 error code E020 01B1, error has not come back after repacement of Y Dev
      • Venom
        Technical/IT Support
        • Nov 2009
        • 765
        Re: canon ir c5250
        Then the drum ground is bad?, swap yellow drum with magenta drum to see if problem follows drum.
        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
        • Andyboachie
          • 185
          Re: canon ir c5250
          I think a sample image of the printout could give a better clue to members.
            • 16331
            Re: canon ir c5250
            Need to print out the internal test charts that shows all the individual colors. Post 'em when you do that. Thanks.
            • charm5496
              • 2387
              Re: canon ir c5250
              There's a ground tab under the drum on the frame. Make sure it is making solid contact with the drum assembly.
              • onmyski
                • Oct 2012
                • 15
                Re: canon ir c5250
                went back this afternoon, cleaned all contacts for Y drum and Y Dev. same proplem. Swapped Y drum with M drum problem went away, so it's a contact problem. Reminder it was a brand new Y drum. test page #10 perfect. Will repost any changes next week.
                Thanks for feedback and suggestions !
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Re: canon ir c5250
                  Best to only use new oem drums complete unit not kits or compatible they rubbish
                  Regards Mark
