ir c5035i advance
  • Gab
    • Aug 2015
    • 676
    ir c5035i advance
    After entering service mode what to select to Release the lock of toner container ?
    Can i do it manually?
    I want to replace the toner container.
    Re: ir c5035i advance
    How remove toner cart on IRAC 5051
    • Gab
      • Aug 2015
      • 676
      In service manual writes to remove process uinit and to remove drum heater . Are these necessary? Can i just slide out the unit and not remove the heater.
      Also i haven't removed toners before i start dissasembly and now they are stuck (the 3 colors) the blk that have the problem easily removed how can i remove toner bottles?
      • Drivee
        • Nov 2020
        • 322
        Hi there
        Follow video, it is easy.
        Replace toner on Canon IR Advance C5030 / C5035 / C5045 / C5051 - YouTube
