Canon imageRUNNER 2630 ERROR CODE E617-9002
  • Jhn16
    • Sep 2019
    • 7
    [Error Code] Canon imageRUNNER 2630 ERROR CODE E617-9002
    Hi there
    Any one who faced this error cose E617-9002 from the machine canon imageRUNNER 2630, 2635 please assist.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4955
    Re: Canon imageRUNNER 2630 ERROR CODE E617-9002
    File system error on Main Controller PCB
    Check the related harness/cables and connectors
    Select "8" in "COPIER> FUNCTION> SYSTEM> CHK-TYPE", execute "HD-CHECK", then turnOFF and ON the main power
    backupdata!
    Select "8" in "COPIER> FUNCTION> SYSTEM> CHK-TYPE", execute "HD-CLEAR", then turnOFF and ON the main power to delete the data in the corresponding partition.
    Enter safe mode using (2+8) startup, and reinstall the system software using a USB flash drive
    Practice makes perfect
    If you want something done right, you have to do it yourself
    • Ezz
      • Aug 2021
      • 2
      i'm having ERROR E617-9999 with Blue Screen and i can't login to Service mode.
      Can anyone help on that.
