C5240A Color and black drum specs along the top and bottom
  • techandtrader
    • Jun 2016
    • 318
    This is the second take over machine I have run into this problem with less than 10k on the color meter and less than 45 on the black meter.
    The drums have a new or newish appearance.
    On the first machine I did not buy that the drums were defective. I put them in a different machine and they have been working just fine for over a year. Maybe they were not setup properly. The specs have an appearance of bursting toner but do repeat like a drum pit! I was amazed when they all disappeared in the other machine. Before I work on this anymore I thought I would post this experience.
    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
    Re: C5240A Color and black drum specs along the top and bottom
    you never stated:
    what is the count on the dev units
    Genuine OEM toner or compatible
    is the machine clean?
    what is the condition of the belt cleaner?
    how many pages on it.
    • techandtrader
      • Jun 2016
      • 318
      Machine is Lab room clean All Genuine toners.
      Whole engine is 40k black 11k color
      Genuine OEM toner
      what is the condition of the belt cleaner? Excellent.
      After scrubbing the drum primary rollers. Ran a tp 10 and found traces of cyan and magenta throughout again.
      Because the drums look like they are new I was hoping to find a reason. I also " Washed" the drum surface with alco. The specs causing the problem are on the charge roller and are not going away. Maybe heat, storage and age played a factor here. New Drums are going in.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Genuine OEM toner
        I don't think the mileage is genuine seems a bit low possible been clocked replace the drums with oem units
        Regards Mark
