Canon dx c5735i with P2 rip
  • papafred
    • Jun 2019
    • 11
    New install. Followed install instruction for copier and rip. Copier is set to 3 to recognize rip. Can print to and see through the rui. We have a strange message on the copier screen that says " check computer name in settings/registration". If we disconnect the rip the message goes away. Tried everything we could think of along with all the clears known. Anyone seen this before.TIA
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Canon dx c5735i with P2 rip
    I think you will find you will have to update system software on fiery we've had problems as fiery was made for irac55xx series
    Regards Mark
    • teckat
      • 16083
      Countermeasures for Each Message
      A computer or printer with the same name is registered in the WINS database.
      When <WINS Resolution> in <WINS Settings> is set to <On>, do not register a computer or printer with a name already listed in <Computer Name/Workgroup Name Settings> in <TCP/IP Settings>.
      A printer or computer with the same name already exists in the same workgroup as this machine.
      Do not register a computer or printer with a name already listed in <Computer Name/Workgroup Name Settings> in <TCP/IP Settings>.I
      • tech17z
        • Feb 2011
        • 7
        When I had this, I changed the server name of the fiery and the message went away.
        • papafred
          • Jun 2019
          • 11
          Thanks for all the input. Changing the server name did the trick.
