Ir 3245
  • bineeshgeorge
    • Jul 2009
    • 107
    Ir 3245
    In an ir 3245 image like this.Both copy and print out, l replaced dc controller,main controller,HDD, hv power supply and laser unit, but still the same fault.Some time no problem,please give the suggestions.
    Sent from my Redmi Note 7 using Tapatalk
  • Brian8506
    • 1623
    Re: Ir 3245
    Have you done anything with the drum or fuser yet? Is the image fused? Is that ltrr direction?
    • bineeshgeorge
      • Jul 2009
      • 107
      Re: Ir 3245
      Yes, replaced fuser filim and drum ,it is A4 direction.
      • bineeshgeorge
        • Jul 2009
        • 107
        Re: Ir 3245
        Image is fused, problem only some time .
        • Brian8506
          • 1623
          Re: Ir 3245
          It looks like Fuser unit or a developer to me. Did you replace just the film or the upper film assembly? Possible bad Toner? Possible dropping Fuser temperature?
          • bineeshgeorge
            • Jul 2009
            • 107
            Re: Ir 3245
            I replaced filim only, there is no fuser related errors.
            • COPIERTEC ASSOCIATES
              • Aug 2011
              • 276
              Re: Ir 3245
              Looks like poor fixing .
              Make a P-print from service mode and after clear DC-CON on service mode then re install settings using the printout you made.
              this is acommon occurance on IR3300
                • 2621
                Re: Ir 3245
                Check the steel leaf spring that presses against the steel registration roller.
                Copytechnet search tool v0.8 Final
