Canon IR 6565ii
  • mastertech
    • Sep 2012
    • 10
    Canon IR 6565ii
    I have 5 Canon imagerunner Advance 6565ii machines that the customer wants to print 13 X 19 on. The paper trays shows, and can hold up to 13 X 19 paper, but you can't register this size on the machine. The PS3 driver gives the option to print 13 X 19 but the machine does not accept this size.
    Has anyone figured out a way to get around this issue? Your help is very much appreciated as my client is very frustrated with this problem.
    The specification on the machine says max size 11 X 17, but the tray has up to 13 X 19. My client wants to switch to Xerox if this issue can't be resolved.
    Ron
  • Hishamawada
    • 174
    Re: Canon IR 6565ii
    Hello,
    Since the specification state it takes 11x17 then it is , the parts inside this series cant print larger then A3 in width .
    But for the length you can try and activate the long sheet option in the service mode and it will give more length when printing from the multi-purpose tray .
    Not sure if available on this series but i use it on ir 8585 and other models , so u can check it.
    Note that the multi-purpose tray is silly to use on production , and could face so many feeding jams and cant hold a lot of sheets at once .
    So if you are willing to hold on the customer , it is best to get for him IR 8585 , it can print up to 33x48 and 33x 62 (on long sheet option) . And the machine is very reliable with very low quality issues.
    Best of luck
    Sent from my SM-G610F using Tapatalk
    • mastertech
      • Sep 2012
      • 10
      Re: Canon IR 6565ii thank you
      Originally posted by Hishamawada
      Hello,
      Best of luck
      thank you
