Canon Image Runner Advance 4245 scan color is off, color with a B/W original
  • tonerjockey
    • Apr 2014
    • 567
    Hi guys, hope you are all doing good.
    this thing was sending green scans from the black and white test pattern with the settings,
    Auto (Color/Gray) 300X300 dpi, Auto size, PDF (Compact).
    i pulled the scanner and cleaned the mirrors and glass.
    sometimes it scans it in black and white, other times its in color.
    i have access to another 4250, but since it is intermittent, i was thinking that the scanner must be ok??
    does anyone have any ideas what could be the cause?
    thank you very much, Jim
  • tonerjockey
    • Apr 2014
    • 567
    Re: Canon Image Runner Advance 4245 scan color is off, color with a B/W original
    now they said the scans are coming in a pink color.
    • nochick
      • Jan 2012
      • 80
      I think scan board or cable is bad try to reseat cable and if the result worse or change that's right?
      I use to found pink and green scan in ir3225 and it's on the edge of photo.
      copy is normal
      B&W scan is normal
      but when color scan there's color on edge.
      You can test on preview scan.
      Good luck
      • tonerjockey
        • Apr 2014
        • 567
        ok, thank you for that.
        i had already re seated the cable at the scanner, not at the board. it had been also giving the error E225-001.
        but i had another same model that was throwing the E280-003 and i replaced the cable for that and so far its been ok.
        the scanners are on back order from Canon.
        thank you very much for the input.
        Have a nice day, Jim
