iR-ADV C5250i displays E100-0300
  • richmond
    • Feb 2021
    • 9
    I keep getting E100-0300, please any help to resolve this?
    The sensor for the Black seems to have a problem.
    • 2621
    Re: iR-ADV C5250i displays E100-0300
    E100-0300 is a laser (2) error have you tried swapping the lasers over.
    If after swapping them over you get E100-0100 you have moved the fault to laser (1)
    The older 5000 series would become ready without a laser connected obviously the colour/black would be missing but at least you can fault find.
    Copytechnet search tool v0.8 Final
    • richmond
      • Feb 2021
      • 9
      Thanks Very much for your reply, it was very helpful and useful.
      I swapped the Laser unit and I had E100-0100 error so does that mean my lasers are not faulty?, then what could be the problem?
      Could it be the blue cable?
      Thanks..
        • 2621
        Thanks..
        The laser is faulty, at the start you had the E100-0300 code which indicates the laser in position 2 is faulty when you swapped them over it told you laser in position 1 is faulty, E100-0100
        The part no is FM0-1021-000, it's the same laser as goes in a 5255 if you have spare machines.
        What happens if you leave the faulty laser unplugged and turn the machine on as I said in my previous post the older machines would actually copy/print like this.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          The problem is a faulty laser unit
          Regards Mark
            • 2621
            @mga that service manual makes more sense than the one I have all mine talks about is laser 1 and 2, although I assumed laser 2 would be the cyan / black.
            • richmond
              • Feb 2021
              • 9
              Thank you my good friends for your great support, it was very useful.
              I replaced the laser unit FC8-3396-2 and the error stopped, it seems to be working now.
              I appreciate your great support.
              Thank you....
