053-0001-05 error code 8595
+ More Options
Posts
  • whymylittle
    • Oct 2019
    • 2
    Hello everyone I get e53 error even though I changed the internal unit and selenoids on the machine I have to try pcb
  • shamil-basayev
    • Nov 2014
    • 5
    Re: 053-0001-05 error code 8595
    E053-0001-05:
    Error in Reverse Upper Flapper Solenoid connection detection
    Detection Description:
    Connection of the Reverse Upper Flapper Solenoid cannot be detected 5 times with 20 msec time
    interval.
    Remedy:
    [Related parts]
    - Harness between the Duplex (UN80/J340) and the Reverse Upper Flapper Solenoid (SL05/
    J2115) (Unit of replacement: CABLE, FIXING/FEEDER DRAWER)
    - Harness between the Duplex Driver PCB (UN80/J300, J301 and J310) and the Fixing Feed
    Drawer Unit (J5005) (Unit of replacement: CABLE, FIXING/FEEDER DRAWER)
    - Harness between the DC Controller PCB (UN01/J431, J9, J432 and J8) and the Fixing Feed
    Drawer Unit (J5005) (Unit of replacement: CABLE, SIGNAL)
    - Harness between the Main Driver PCB (UN78/J108) and the Relay PCB (UN86/J522) (Unit of
    - Harness between the Relay PCB (UN86/J517) and the Fixing Feed Drawer Unit (J5005) (Unit of
    - Reverse Upper Flapper Solenoid (Unit of replacement: REVERSE SOLENOID ASS'Y)
    - Duplex Driver PCB (UN80) (Unit of replacement: DUPLEXING DRIVER PCB ASSEMBLY)
    - Relay PCB (UN86) (Unit of replacement: RELAY PCB ASSEMBLY)
    - Main Driver PCB (UN78) (Unit of replacement: MAIN DRIVE DRIVER PCB ASS'Y)
    - DC Controller PCB (UN01) (Unit of replacement: DC CONTROLLER PCB ASS'Y)
    [Remedy] Check/replace the related harness/cable, connector and parts.
    [Reference] Before replacing the DC Controller PCB, back up the service mode data (approx. 2
    min) and restore the backup data after the replacement so the data may be able to be protected.
    - Backup: COPIER (LEVEL2)> FUNCTION> SYSTEM> DSRAMBUP
    - Restoration: COPIER (LEVEL2)> FUNCTION> SYSTEM> DSRAMRES.
