Canon IR5000, Build a job?
  • ar6565
    • 94
    Many times I need to copy group of sheets from the two sides different modes.
    The first side will be on very light photo mode.
    The second side will be on dark text mode.
    Putting the paper in the copy glass and repeating these job many time repetitively is a silly job.
    Are there any way to build this job and save time and effort?
  • SCREWTAPE
    • Jul 2025
    Do you have doc feeder?
    Have you tried using job build in special features?
    Job Build Mode:
    1. Place the first set of originals in the Document Feeder and press the Special Features Key
    2. Press the Job Build Key.
    3. Press Done (The display will return to the basic functions screen).
    4. Press the Start Key to start scanning the originals.
    5. When Scanning is complete, place the next set of originals in the Document Feeder.
    6. Press Start to scan the next set.
    7. Repeat steps 5 and 6 until the last set of originals is scanned, then press the Done Key to print out the entire combined document.
    Hope this helps.
    • ar6565
      • 94
      Thanks SCREWTAPE.
      Yes, I have a DADF-D1.
      I tried the steps you gave to me with three originals, but the three originals where copied into 6 sheets.
      I need them to be copied on a three sheets each side copied with different mode (Photo/text).
      • SCREWTAPE
        • Jul 2025
        Im not sure you can do this, switching text and photo mode. There is a photo mode option in copy settings but again im not sure that will work also. Look at a copy guide manual if you have one maybe you will find something. Goodluck,
        Screwtape.
        • ar6565
          • 94
          Many thanks.
