Need help solving error 100-0001 in Canon IR 3300
  • NeverSayNever
    • 6
    Hello everyone! I need help solving the error 100-0001 in Canon IR 3300. I have tried cleaning the laser scanner unit. But it didn't work. I hope that replacing it would fix the issue. But it would be great if someone helped me to solve this without replacing it.
    Thanks in advance!!
  • Brian8506
    • 1664
    • Pete from Prescott
      • Feb 2012
      • 26
      Re: Need help solving error 100-0001 in Canon IR 3300
      • If you've got another unit laying around you might try swapping these units mentioned below. Otherwise, You should probably move on.
      • Causes:The wiring is faulty (short circuit, open circuit). The BD PCB is faulty. The laser scanner unit is faulty. The DC controller PCB is faulty.
      • Remedy:1. BD PCB Try replacing the BD PCB. Is the problem corrected? YES: End. 2. Laser scanner unit, DC controller PCB Try replacing the laser scanner unit. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.
