Canon MF5770 help
  • c5770
    Canon MF5770 help
    I have a Canon MF5770. It displays "Download Standby" as soon as it's plugged in to AC. With USB cable plugged in it displays "Download Connected". What to do?
    I am not a tech.
  • victor_v
    • 71
    Canon MF5770 help
    Hi c5770
    It means, that on your device the operational system has fallen. And at connection USB on the display there is a message on readiness for an upgrade.
    Good luck.
    Hardworking people are not present. Simply many it is boring to idle.
    • jamezg
      C5770,
      I had this problem with same model. The solution that worked for me is to update the firmware. The canon website should have the firmware update and instructions for running it. Once that was applied over a USB connection the unit rebooted and was fully functional again.
      Hope this helps.
      Link to the MF5770 canon website :
      Canon imageCLASS MF5770
