Canon MF 633 CDW -COLORS PROBLEME-
  • raztech
    • Dec 2008
    • 88
    Hello dears
    may be someonecould help me to calibrate colors in canon mf 633cdw ( colos : red -bleu-yellow ) are not so dark ..and couldnt adjust theme....it makes me a clear copy....
    thanks for your help in advance
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4955
    Re: Canon MF 633 CDW -COLORS PROBLEME-
    Adjusting Image Quality
    Check drums lifetime.
    Practice makes perfect
    If you want something done right, you have to do it yourself
    • raztech
      • Dec 2008
      • 88
      Hi again..
      Have changed for new package........
      still have a problem ..-message eror-
      couldnt perform correction ...
      • zoraldinho
        • Mar 2008
        • 4955
        What is the image quality on itb?
        ok-clean patch sensor
        neg-clean/inspect laser unit
        OEM cartridges?
