Canon 400if
  • bighut
    • Sep 2018
    • 5
    [Misc] Canon 400if
    I have a canon 400if i am working on. It was having lines come out acrossPrint from Canon 400if.pdf the page when I print copy. I rebuilt the whole drum unit and still have the line going across the page. Ant idea would be helpful.
    Re: Canon 400if
    Originally posted by bighut
    I have a canon 400if i am working on. It was having lines come out across[ATTACH]48952[/ATTACH] the page when I print copy. I rebuilt the whole drum unit and still have the line going across the page. Ant idea would be helpful.
    the drum isn't the only thing that causes lines.... developer..fuser..transfer roller
    give us the life counts on all service parts....
    your PDF doesn't open for me
    • bighut
      • Sep 2018
      • 5
      Re: Canon 400if
      I have enclosed the PDF another way
      • bighut
        • Sep 2018
        • 5
        Re: Canon 400if
        I have sent a readable pdf if that can help
          Re: Canon 400if
          ok forget the pdf,, still doesn't open.
          please give us the life counts on service parts.
          did you completely clean the insides of the machine?
          • bighut
            • Sep 2018
            • 5
            Re: Canon 400if
            I have the developer unit out now and will clean the inside it does look pretty yucky. Can I please get back to you after the cleaning?
              Re: Canon 400if
              Dev unit out?
              Is there a nice coating on the mag roller?
              DO NOT blow it out. Big mess in your future.
              Do you have the special toner vac? If no.. DO NOT vac with house vac.
              I asked for the service parts page counts.
              • bighut
                • Sep 2018
                • 5
                Re: Canon 400if
                Dev unit out?
                Mag was fully flourished
                Switched transfer roller and fuser still same problems.
                Didn't switch dev unit yet
                I have three of these machines
                I did take dev unit and clean the inside, it was a mess with paper particle shred. I cleaned real nice with my toner vacuum. still comes out with vertical lines. When I get into service mode how do I find the service parts page?
                • Venom
                  Technical/IT Support
                  • Nov 2009
                  • 765
                  Re: Canon 400if
                  Those marks look like either hardened toner on mag roller or the drum is making contact with mag roller from worn bushing.
                  IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
