Download FONT
  • giogi
    Engineer senior
    • Jan 2016
    • 181
    Download FONT
    Do you know how to download fonts to the Canon ADV device?
    NO EFI controll
    thanks
    "Knowledge is a source, but unfortunately ignorance is a sea."
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Download FONT
    I'm not familiar with downloading fonts. In what case would you need this?
    But I saw they sell the PCL International Font Set-A1 as an accessory. Is this maybe ...?
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      Re: Download FONT
      PCL and Post Script options adds more fonts to the MFP, The newer Canons come with these as standard.
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • giogi
        Engineer senior
        • Jan 2016
        • 181
        Re: Download FONT
        I found:
        The Canon IR-ADV MFDs are shipped with the standard catalogue of traditional office fonts.
        However, there may be occasions where a client requires specific fonts to be loaded onto their MFDs for tailored printing needs.
        An example situation is a direct print customer sending PostScript files directly to their MFD with a custom font.
        To identify what fonts have been loaded onto your MFD, you can use the following menu option:
        <Menu> <Output Report> <Print List> <PS / PCL> <Font List>
        The MFD will then print a font list showing all of the fonts loaded for the engine selected.
        To load fonts on your MFD, must be used.
