ir400 / ir330
  • copyj8
    ir400 / ir330
    Just installed a used printer board trying to replace old dead one and new problem (last board was no longer seen by copier) . System starts up fine, but when select "print I.F" key, then "functions", there is no setup button. only "print pages" or "reboot server" show up so I cannot configure board. PLEASE HELP!!!
  • banty
    • 36
    print board/ fierry problem
    Just pull out the RAM from print board, clean it properly and clean the socket also, install it again and try to configure. i think this will work.
    -Mehul
    • copyj8
      Thanks, I will try that.
