CANON C5550i Scanner Problem
  • mkarip
    • Feb 2010
    • 31
    [Misc] CANON C5550i Scanner Problem
    Dear Friends
    Got a problem with C5550i
    A yellow 3cm bar appears on Scan & Copy.
    B / W copy & scan OK.
    Internal color printouts and prints from PC are all OK.
    Drum ITB as good as new.
    Seems like a scanner problem. Glass etc. everything clean.
    I am grateful for all suggestions.
  • dekoster
    • Aug 2012
    • 84
    • dekoster
      • Aug 2012
      • 84
      • mkarip
        • Feb 2010
        • 31
        Re: CANON C5550i Scanner Problem
        yes
          post in native language and use a translator to english and post that also please
          • mkarip
            • Feb 2010
            • 31
            have a problem with C5550i.
            Scan & Copy display a yellow 3 cm bar.
            B / W copying and scanning OK.
            Internal color printouts and printouts from the PC are okay.
            ITB drum as good as new.
            Seems to be a scanner problem. Glass etc. everything clean.
              • 2621
              Do one colour copy from the glass at standard settings
              Do another with a magnification of say 25% does the yellow line move?
              Could it be dirt on the scanner white reference plate? Kyocera's have this under the main scanner glass, I have forgotten where this is on a Canon.
              Take the slit glass and main glass out and look for a white strip underneath, clean it.
              • mkarip
                • Feb 2010
                • 31
                Problem solved: It was the lower scanner unit.
