VarioPrint 6180 code 11565
  • Ajaxfan77
    • Sep 2009
    • 48
    [Error Code] VarioPrint 6180 code 11565
    Hi everybody
    Can anybody help with Oce VarioPrint 6180 fault code is 11565
    Thanks in advance
  • Hishamawada
    • 174
    Re: VarioPrint 6180 code 11565
    Hello ,
    first of all check the connections for all the Can Bus cables to the main node .
    Check the main node power.
    check if there is power on/Off buttom and try to manually switch it on.
    If you have Sds licence , you need to try and force embedded software .
    Sent from my SM-G610F using Tapatalk
    • Ajaxfan77
      • Sep 2009
      • 48
      Originally posted by Hishamawada
      Hello ,
      Can you sen pm?
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Originally posted by Ajaxfan77
        Hi everybody
        Thanks in advance
        Error 11565=No Logical FTP connection with Engine
